Danke für die Hinweise, im Netz bin ich auf das mazda bulletin 01/005 24 gestoßen. Bin gespannt was mein Händler dazu sagt.
PYFD-15-16ZA ist wohl die überarbeitete und empfohlene Version, die das ältere PYFD-15-16Z ersetzt.
Hier:
TSB Number:SSPD8 REPAIRNHTSA Number:11016300TSB
Date:March 11, 2025
Date Added to File:April 2, 2025
Failing Component:Engine
Summary:Sspd8 - special service program warranty extension - multi-model - check engine light on with DTC
P0126:00.Mazda motor corporation has decided to conduct a special service program (ssp) to extend the warranty coverage for a specific repair of the fail-safe thermostat in the coolant control valve on certain cx-5, mazda3, cx-3, mazda6 and cx-30 vehicles that are equipped with the suspected coolant control valve. The warranty coverage for a specific repair of fail-safe thermostat has been extended to 15 years (180 months) /150,000 miles (240,000 km) whichever comes first, from the original warranty start date. Concern outline
n certain subject vehicles, the check engine light is illuminated with DTC
P0126:00 (thermostat stuck open) stored in memory and one or more of the following symptoms may occur: engine takes longer to warm up, engine temperature gauge fluctuates, low coolant temperature indicator (blue) light stays on longer or turns on while driving, poor heater performance, especially at idle.This is a warranty extension for the specified repair only. Inspection and replacement of non-failed parts will not be eligible for reimbursement under this ssp to the dealer or customer. This program extends the warranty period for actual failures due to defects in workmanship or materials in accordance with the mazda warranty policy and procedures. If a customer arrives at your dealership with the concern described, please repair under this special service program.
