Anleitung: Einbau Rückfahrkamera FL
What do you mean with:"a Instrument Cluster programation"?
Could you explain it please a bit more detailed?
Furby
MZD dont work as NB1 with camera.
NB1 once detect camera dont forget it.
MZD need to know what camera is installed.
MZD looks for camera in start but if not video in camera input dont show it.
OEM camera only send video with reverse engage.
OEM camera Its on MSCAN but MZD is on HSCAN and Instrument Cluster is a bridge into MSCAN and HSCAN.
Enviado desde mi iPhone utilizando Tapatalk
That`s true.
Yes
Yes
That`s true
This is also true.
And this sentence i don`t understand....please, can you describe what you did to get that lines moving to the driving direction??!!
Thank you for your effort.
Greetings Ralf
Enviado desde mi iPhone utilizando Tapatalk[/QUOTE]
Dinamics lines come from camera,
Camera send video signal and dinamic lines.
This camera have 7 wires:
+12V
Ground
Video Signal
Video ground
Video Shield
MSCAN L
MSCAN H
MSCAN wires it connect to RBCM in Trunk
I used a tutorial I found in the post of camera for original cx-5.
Okay, You used original RCBM, and not the Sportsline RCBM and "just" conneted one "more" cable to MS can?
The OEM Camera is normaly not Connectet to RCBM.
Is this right?
greets
Furby
Is this right?
greets
Furby
No,OEM camera Its connected to RBCM.
I use original wiring scheme for CX-5 F/L
RBCM connector have two free pin for camera.
Tomorrow i will upload wiring schemes i used to do it.
That would be great, and i think very helpfull for many members here.
thanks
I found wiring schemes in my phone.
I found the camera i installed too.
I hope it help you.
So, heute dann mal endlich dazu gekommen und die Kamera mittels des folgenden Steckers angeschlossen...
Was soll ich sagen...
LÄUFT!!!
An dieser Stelle vielen Dank für die Tipps, die ich hier im Forum für diesen Einbau bekommen habe. :D
Dem kann ich mich nur anschließen, auch bei mir läuft es mit diesem Stecker problemlos. Die Lieferung dauerte etwas mehr als 2 Wochen, kam aus Hongkong.
ruckfahrkamera help wanted
Hello
i could use some help with the instalation of my rfk in my 2012 cx-5
i orderd this set:
https://nl.aliexpress.com/item/Car-Rear-View-Camera-Back-Up-Reverse-Parking-Camera-For-Mazda-CX-5-CX-5-CX5/32295653819.html?isOrigTitle=true
And i thougt it was plug and play.
ive plugged in the camera wires on the back of my navigation screen.
and put 12v on the wires (i've used the 12 v pin in the little fusebox next to the clutch pedal. yust for testing
But it didn't do anything i was wondering if the blue wire should be connected to the 4th pin on the large powersuply plug, but in my case this is already occupied.
The car is a 2012 cx-5 2.0 ts+ with safety pack
And because i'm already busy with asking some questions one more, what is the nicest place to connect those 12v suply wires permanently when everything works properly?
Vielen dank
p.s i will try to introduce myself properly next week with some nice pictures
Nick (from holland)
Thanks i,ll try to Find the pins to connect the wires to the camera plug, And try to fix it this way.
Im wondering whats inside the Black box. It isnt a fuse, so maby it,s a convertor? I doet know what else it could be
Off-Topic:
Derzeit gibt es wegen einer Softwareumstellung leider Fehler beim Hochladen und automatischen Verkleinern von Bildern.
Das kann man vorläufig umgehen, indem die Bilder bereits vor dem Hochladen auf (B) 800 x (H) 600 Pixel verkleinert werden. Ich verwende dazu z.B. irfanview
