Seite 40 von 40 ErsteErste ... 30383940
Ergebnis 391 bis 396 von 396
Thema: Aktivierung versteckter Funktionen bei Mazda CX5
  1. #391
    Benutzer Avatar von Mazda23
    04.08.2014
    RP-Kreis
    Erhielt 1.377 Danke
    Den Schalter hast du an allen 4 Türen.
    Nur mit dem Schalter an der Fahrertür kannst du alle 4 Türen verriegeln/entriegeln.
    Die anderen 3 Schalter an den Türen steuert jeweils nur die betroffene Tür.
  2. Für diesen Beitrag bedanken sich bei Mazda23 folgende User:
  3. #392
    20.05.2019
    UK
    Erhielt 0 Danke
    Activation
    Hello guys I have a Mazda CX-5 2.2D Sport Nav 2014 and I'm based in the UK.
    I have tried my best to activate
    Leaving Home Light
    Unlock Mode 2-Step
    option for SBSC R on instrument cluster display
    I-DM Because Japanese 1st generation CX-5 have them
    but remain unsuccessful
    Can anybody help me please
  4. #393
    04.11.2016
    Frankfurt am Main
    Erhielt 3.846 Danke
    We can try, if you tell us:
    1. How do you expect us to help?
    2. What have you already tried?
    3. What's exactly the problem?
    4. How are your original data from the necessary modules?
  5. #394
    20.05.2019
    UK
    Erhielt 0 Danke
    I have used Sergslim's excel spreadsheet and forscan.
    i have activated autolock when driving off
    i have activated coming home light
    i have activated find my car but it does not work very well
    please look at the video to see what i mean
    https://youtu.be/S5tleaEjQss
    is it possible to have i-DM like this car from Japan?
    https://youtu.be/DtBXfJyuJIU
    i want to know if i have SBSC-R and how make it show on the instrument cluster
    R_BCM
    ;Block 1
    7B701019DD20006E91E
    7B70102E501D300209A
    7B70103002890007A
    ;Block 2
    7B70201303850987081
    SSU
    ;Block 1
    73101010834E024209A
    7310102180C1E479054
    73101030220005E
    ;Block 2
    7310201900400CF
    IC
    ;Block 1
    7200101A32279A6808D
    7200102B2F7190000EC
    720010300000000002B
    720010400000000002C
    720010500000000002D
    72001060000002E
    ;Block 2
    7200201BAF700DB
    ;Block 3
    7200301012C
    ;Block 4
    720040118FA0080FFBD
    7200402FFFFFFC100EB
    72004034A4D5A4B45AF
    720040446C1013931A1
    720040536303031C1B8
    7200406023732373104
    72004073900C1033867
    7200408002989220007
    7200409C10400000801
    7200410BE0000BF01B9
    720041141000000007D
    720041200BF0220001E
    720041300000003BF00
    7200414033000020074
    72004150000BF043033
    7200416C00000000001
    7200417BF0510000016
    7200418000000BF0608
    7200419100000100064
    720042000BF07000011
    720042100100000BF1B
    7200422082120010097
    72004230000BF092036
    720042400002000006F
    7200425BF101000002F
    7200426000000BF1121
    7200427000000000052
    72004280053
    F_BCM
    ;Block 1
    7260101F240016E5828
    726010264AAD35456BB
    726010352AAAAA67D
    ;Block 2
    72602017FAF
    ;Block 3
    72603017FB0
    ;Block 4
    7260401083A
    ICA - Smart City Brake Support
    Part number: GHP9-67XD0-B
    Strategy : KD45-67XD02-AA
    Calibration: GHP9-67XD05-AA
    Total Distance: 110075.0 km
    ABS - Antilock braking system
    Part number: KJ02-437A0-
    Strategy : KJ02-437AS-0-00
    DSM - Driver's Seat Module
    Part number: GHL2-675J0-
    Strategy : GHL2675J1A01
    RCM - Restraint Control Module
    Part number: KR32-57K30--
    Strategy : KR32-66853---31
    AFS - Adaptive Front Lighting System
    Part number: KD54-5102X-00
    SSU - Start Stop Unit
    Part number: KD45-675S0-M
    Strategy : KD45-675S1-M-00
    EPS - Electronic-Controlled Power Steering
    Part number: KJ01-3210X-A-
    Strategy : KJ01-3210X-A-00
    F_BCM - Front Body Control Module
    Part number: KD45-675X0-
    Strategy : KD45-675X2-B-00
    IC - Instrument Cluster
    Part number: KH26-55430-0
    R_BCM - Rear Body Control Module
    Part number: KD45-675Y0-G
    Strategy : KD45-675Y0-C-00
    EATC - Electronic Automatic Temperature Control
    Part number: KH26-61190-
    Strategy : 5-4-0
    Geändert von TCoker (16.07.2019 um 13:07 Uhr)
  6. #395
    04.11.2016
    Frankfurt am Main
    Erhielt 3.846 Danke
    Do not expect too much here, as the real pros for reprogramming modules can be found here in another forum.
    But in general you know how to use the XLS of serg slim - that`s good, as you then can generate your own values.
    i-DM: Don`t know. Have not had a look at that ever. But I would try these settings:
    Leaving home: Just search with "leaving" in this thread - there probably was a discussion about it. Perhaps it only works if you activate the lights/high beams.
    SCBS-R: I only activated it at my CX-5 2016 with MZD and I know that you have to have the car in the upper right corner when the rear camera is active - otherwise your PSM-Module is not there or not capable of SCBS-R. And in my car (not the highest equipment line) there is no own new menu item for SCBS-R in the MZD. The menu stays the same. I could only test SCBS-R to see if its activated - eg. using stapled empty cardboards/moving boxes for a test drive against them. For more info see this post.
    Door Unlock: See also the manual for the Napoli-Schaltung in Post #1. Perhaps you only activated it in the RBCM, but not for the CMU (the two right values in the following screenshot):
    Good luck.
  7. #396
    20.05.2019
    UK
    Erhielt 0 Danke
    Good luck.
    Thank you very much for your help.
    I have tried all the procedures and no luck.
    Looks like CX-5 KE 1st Generation are not possible to activate these options
  1. Gebrauchtwagenkauf CX-5 vom Mazda Händler - versteckter Mangel - wer noch?
    Von JanD im Forum Mazda CX-5 Probleme, Mängel & Lösungen
    Letzter Beitrag: 06.07.2016, 11:51
  2. Video Anleitungen zu CX-5 Funktionen
    Von JimmyTheFreak im Forum Mazda CX-5 Allgemein
    Letzter Beitrag: 07.04.2016, 16:26
  3. Versteckte Funktionen beim CX5
    Von crazypainting im Forum Mazda CX-5 Allgemein
    Antworten: 6
    Letzter Beitrag: 03.04.2016, 15:59
  4. Mazda CX-5 Coupé (oder Mazda CX-4 = Mazda Koeru)
    Von webster im Forum Mazda CX-5 Allgemein
    Letzter Beitrag: 18.08.2015, 20:03
